06 Led headlights
jbrandes
Has anyone had luck swapping to Led headlights on 06 3500 Cummins
J
jbrandes
I've tried two brands one with attach decoder and one with detached no combination worked on dim the brights were great though Dim works for a few minutes then not yet again they flash like a strobe then dead .but again brights no problem both side are insync doing the same thing at the same time.
CanuckRam1313
Ontario Canada
2023 Warlock
I think your truck takes (H13) 9008 for the highs and lows, and 9006 for the fogs.
Great bulbs, no CanBus issues, slim design fits under the dust covers.
Make sure to clock and aim them correctly :)
J
jbrandes
I've tried two different brands one with a decoder attached and the dims would not work . They did at first then stop.
Second brand I tried without a decoder and same thing . Added a decoder and it did not help.
CanuckRam1313
Ontario Canada
2023 Warlock
What do you mean click them ?
Clocking them means to set them to the correct orientation where the LED bulbs are at the 3 & 9 o'clock positions.
The LED's need to be facing left & right, not up & down. Make sense :)
This will ensure the best beam pattern for optimal light output.
