07 1500 big horn problems after battery replacement
fedves86
Manteca
5 7 hemi
Hello everyone, I have a ram, the battery drained overnight from leaving the keys on in it, I put the battery on trickle charger for a day put battery in and it ran for a few miles, got back drive it some .ore so I left it running to run in the house for something when I came back out the truck had turned off I started it as it run it ran for about 2 or 3 minutes before it shut itself offhe keys on in it, I put the battery on trickle charger for a day ran the scan tool and it's got like 20 something codes about the passenger control restraint system a bunch of other stuff it says it's shorted out and they can't communicate with the tipm canbuss problems etc. Then the OBD2 port stopped working and I couldn't get any readings off of it anymore luckily I had the screenshot on my phone of what was wrong with it but I don't think that really matters something else is going on now I can't start the truck at all if I disconnect the battery and I let it sit for a couple of hours and put it back in and connect the wiring to each terminal it will start up for a minute or two and then it'll shut itself off again the battery is not bad and neither is the alternator I had them both checked I even hooked up my battery to my DC stick welder just in case there was something wrong with it holding a charge or something it looks like something is in some security mode has taken over I have the original Factory keys that I'm trying to use to start the truck any advice is appreciated, I'm and all of the lights on the dash came on I took my scan tool and ran the scan tool and it's got like 20 something codes about the passenger control restraint system a bunch of other stuff it says it's shorted out and they can't communicate with the tipm canbuss problems etc. Then the OBD2 port stopped working and I couldn't get any readings off of it anymore luckily I had the screenshot on my phone of what was wrong with it but I don't think that really matters something else is going on now I can't start the truck at all if I discowelodnddy#bjweji32o9qonnect the battery and I let it sit for a couple of hours and put it back in and connect the wiring to each terminal it will start up for a minute or two and then it'll shut itself off again the battery is not bad and neither is the alternator I had them both checked I even hooked up my battery to my DC stick welder just in case there was something wrong with it holding a charge or something it looks like something is in some security mode has taken over I have the original Factory keys that I'm trying to use to start the truck any advice is appreciated, I'm in dire straights right now, I need my truck back asap. Thank you
F
fedves86
Manteca
5 7 hemi
Wow I just reread my post I think something happened between me hitting post and it posting Jesus. anyway I just bought a new die hard platinum for 250 bucks and it will not start at all now these lights are on and I hear no ticking or anything when turning the key, I can hit wire the starter and it works it seems but something happened when the battery was drained that right me here to where I'm at now.
Daw14
South Florida
Final results ?
No members online now.
KAKA
