07 Ram 1500 check engine light question
djjab73
I have a code for the gas cap, replaced cap with one from dodge but didn't fix the problem. I heard that this is a common problem but can't find the answer. TIA
MADDOG
Living in a Firepit
6.4L HEMI
It means you have a leak in the fuel evap system.
It could be a hose that runs from the engine compartment to the evap canister. There is also a loop hose on top of the canister that could be cracked.
