08 with no power at all
4inch_is_avg
Canada
08 1500 with no power at all. Went to start it a couple days ago and got nothing so I changed out the starter went to start it up and got a pretty loud pop from under the hood. Prior to the pop everything had power. Checked all the fuses and everything looked fine so I’m kind of stumped. Everything I’ve been reading indicates to a bad tipm but again I’m kind of clueless as to what the problem could be. I have a list of codes available to share if someone wants a little more insight to help me diagnose the issue
tron67j
Maryland
Codes would definitely be helpful.
Why did you replace starter? You indicated no power, does that mean no dash lights or anything turning on? Did you load test the battery to determine if amps hold under load?
4inch_is_avg
Canada
I replaced the starter because I went to start it when everything still had power because it was stuck and clicked when I went to start the truck. No power to absolutely anything. The battery was taken from one of my other 1500’s and was working fine in it.
Car Scanner ELM OBD2
Version: 1.121.0/1.121.0/iOS
OBD-II
No DTC found.
Engine control unit
No DTC found.
AmplifierAmplifier
DTCs: 2
U0184 [0xC184]
Data bus, radio - no communication
Status: Validated and stored in non volatile memory, Validated fault present at time of request
B210E [0xA10E] Archive (inactive)
Front controlFront control
DTCs: 9
C1469 [0x5469]
Status: Test has not been completed, Validated and stored in non volatile memory
B210D [0xA10D]
Status: Test has not been completed, Validated and stored in non volatile memory, Validated fault has been present during this drive cycle
U0024 [0xC024] Archive (inactive)
Controller area network (CAN) data bus, low speed bus (-) - open circuit
B165E [0x965E]
Status: Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
B1634 [0x9634] Archive (inactive)
B1638 [0x9638] Archive (inactive)
B1630 [0x9630] Archive (inactive)
B1661 [0x9661]
U0184 [0xC184]
Hands free
No DTC found.
Heater, ventilation and A/CHeater, ventilation and A/C
DTCs: 3
U0019 [0xC019] Archive (inactive)
U0184 [0xC184] Archive (inactive)
B104B [0x904B] Archive (inactive)
Instrument clusterInstrument cluster
DTCs: 5
B210F [0xA10F] Archive (inactive)
U0141 [0xC141] Archive (inactive)
Data bus, body control module (BCM) A - no communication
B2213 [0xA213]
U0156 [0xC156] Archive (inactive)
Data bus, information centre A - no communication
Second row screenSecond row screen
DTCs: 2
U0184 [0xC184]
TPMS (wireless control)TPMS (wireless control)
DTCs: 5
B210A [0xA10A] Archive (inactive)
B210D [0xA10D] Archive (inactive)
B1A28 [0x9A28] Archive (inactive)
C0077 [0x4077] Archive (inactive)
Low Tire Pressure
RamDiver
Marlborough, Ontario Canada
2021 DS
That looks like a typical DTC storm, often caused by a inadequate battery.
Step 1 is to charge the battery and then load test with a toaster-style battery load tester like the following $28 device.
Rp3412
