09-12 DBALL Remote Start
Status
Not open for further replies.
DannyMK2
Long Island, NY
2015 Power Wagon
i have a used DBALL remote start setup that is compatible with 09-12 rams with gas motors. complete setup with t-harness is plug and play. works by hitting the lock button 3x. i wired in an on/off switch to disable the remote start if you need to take the vehicle in for service. i can email the install instructions which contain wiring diagrams if you wanted to wire in the parking lights and hood pin switch (i didnt). the unit has operated flawlessly for the last 2 years. only removed because i wanted to install an alarm, which required a different module and t-harness. id like to get $100 for it. if anybody local buys it i can assist with installing it. only takes about 10-15 mins.
67datto
Where you located?
Sent from my SM-N910T using Tapatalk
cbo
Im i.terested.what exactly is involved in the installation? Will tis fit all '12 rams (i have a 5.7 express auto)
D
DannyMK2
Long Island, NY
2015 Power Wagon
fits all 09-12 rams with gas motors and auto transmissions. i have a 2012 express as well. installation is basically disconnecting the ignition module and plugging in the t harness. then connect the ring terminal to a ground (if you want the on/off switch to work). programming is as simple as turning the ignition on, then off and hitting a button on the key fob. i have the detailed instructions, but thats the general gist of it.
67datto
I am in Tampa. Let me know if you'd ship. Thanks
cbo
Ill take this if ita atill available. Please contact me at 609.618.6945 thanks.
arod412
Philadelphia
Man...I could sure use this....as you know the north east winters can get cold. Let me think about this
2012 Ram 1500 quadcab
**Sent from the *********
D
DannyMK2
Long Island, NY
2015 Power Wagon
Summer, winter...i use the remote start almost every day. best investment ever. no ones pulled the trigger on this yet so if either of you are interested, let me know.
arod412
Philadelphia
Funny thing is that I'm heading to long Island on new years eve to see some friends..lol. you had it available since july?
Status
joshhhh
