09 1500
FXDR
tn
About to pull the trigger on a 09 1500 crew cab with hemi and around 47k miles. What should I expect as far as reliability and problems.
McBroom
Denison Tx
Hemi 6.4L
Is it a 4x4?
#1 Exhaust manifold bolts.
Blue Streak Pearl off-road
Nate4x4
The Vehicle Reader
ON, Canada
5.7L Hemi 4x4
My sister is also hoping on pulling the trigger on a 09 1500, but with a lot more than 47K miles.
Problems and reliability will be based on it's before life (previous ownership treating). I'd check into that. Damage, Malfunctions, etc.
2009 being the year of beauty change (design) for the Ram 1500. I overall will highly recommend it (with that fact, that it's 4x4)...it has a lot of potential for the year and miles declared.
Cheers,
Nate :waytogo:
indept
South Jersey
Search here in the Engine & Performance section, the early 4th gen years had a lot of lifter failures and wiped cams. Not cheap to fix.
RamRoy
Crestview, Florida
Original owner of my 09 4x4. 180,000 miles and going strong. Only problem was exhaust manifold bolts broke. Had them repaired under powertrain warranty.
huntergreen
Marine Corps Navy Badge
Does it have maintenance records ?
