1 inch Body Lift 100 Shipped
Status
Not open for further replies.
Oefootball_70
OLATHE
Dodge Ram 1500 02-05
I just got finished removing the 1 inch BL from my truck. I am asking 100 dollars shipped.
Included are the items needed for a QCSB to make it work on a RCLB you would need to use two of the factory bolts from the cab on the bed and you would be set.
For it to work on a QC LB you would use all the bolts provided and two from the cab on the bed.
QCLB see the notes bellow also work for you RCSB you just don't use the two extra Cab bolts/pucks.
SO included is what is pictured bellow. 14 bolts (8 for the cab 6 for the bed)
16 pucks ( I ordered two extras just in case this comes in handy for the QCLB)
And four crush blocks, you would need to get these tack welded or industrial zip tie them down. I did both.
PIctures bellow....
Oefootball_70
Oefootball_70
OLATHE
Yes. The 4x4 and 2wd share the same bolts.
As far as bumper brackets, there are none. You have to, like I did. Dremmel the brackets one inch at the bottom of the holes to move the front bumper up one inch. The rear bumper has an inch ( or really close to it) of play that you can move it up.
Oefootball_70
Oefootball_70
OLATHE
Drive to KC KS and save on shipping, but would probably cost more in gas, lol.
HKkid
Missouri
Yeah, how long did it take you to install?
Oefootball_70
Oefootball_70
OLATHE
I took it off today in 2.5-3 hrs. I have the step up bars so it took me a little longer taking them off and such.
But the dremmeling of the brackets does take a little bit of time. (Good thing is it isn't required to run the lift, so you can install lift one weekend come back and take care of the brackets the next.)
Whoever buys this I will PM a link to instructions.
Oefootball_70
Oefootball_70
OLATHE
Bump will make deal with Suspension lift/BL combo.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Where can a Guy Procure this BL New, Ryne? or is it something Home-made.
Oefootball_70
Oefootball_70
OLATHE
You can buy the "pucks" from Performance lifts.com, the bolts you can buy at a hardware store (just make sure to get the right thread and length), and the crush blocks i had cut at a machine shop.
Oefootball_70
Oefootball_70
OLATHE
If the price is too high PM me an offer. I was trying to keep low ballers away, but I seem to have scared off everyone.
02ram
around
4.7L
If you have this this weekend i will take it just need to get payed first
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Thanks for the Info, If Mike Changes his Mind, I'm Still Interested.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Ryne, Your MailBox PM Thingy is Full Man, So I'll post here!
Received the BL Today, 1 Week Fast.....Thank-you. Tracking # was on top. 2 Small Questions. Do I need to slack off the steering extension so it can move up an inch? and what about the Gas Tank Hose, same? I have a Piece of 1 inch stock for between the bumper and Hitch (where it bolts under the step pad). BTW. Will do the Itrader or whatever its called.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Bump For Ryne to maybe answer above Questions. This is gonna be put on this weekend as we expect unreal weather such as 62 Farenheit.
Status
Arturo Rojas
