johnspd
I'm back at my dealership for the 3rd time since I purchased my 2020 Ram Laramie Sport 4x4 on May 9th. The first time, the screen was defective and was replaced. I'd owned the truck for 5 weeks. It worked fine for 3 days, then started acting up again. In September I experienced the longest period without audio...an entire day while traveling to SE Kansas on a charity ride of 433 miles.
Like others I've talked to, my 12 inch Uconnect will either scan and not find a channel, or simply not scan at all. I can connect my Android to it (no, I don't use the Uconnect Android App. It takes over you phone and does what it wants to do and not what you want it to do.), however, if you get a call, you can't answer it because the Uconnect isn't working. Also, the volume is stuck on the radio and forget about Bluetooth, it won't connect either. I was actually able to drive the 35 minutes to my dealership last week and have them see what the radio was and wasn't doing. Fortunately, the climate control system and other app.
Join the club, the 12" system is junk. The dealership can't replace it until Chrysler says they can. I am in the same situation. I don't have a high degree of confidence that once they replace mine the issues will go away. From the reading I have done it sounds like this is most likely a hardware design issue (possibly not enough memory). The 2021 12" system is a new design by a different manufacturer and is not compatible with previous year models.
