12 V outlet always on
clayusmcret
Moundridge, KS
Hemi etorque
Can confirm that it's the 20amp fuse in 54a/b. Default it's in left/middle. use the fuse puller from the engine box (or whatever you'd like) and swap it to middle/right. I cannot verify the lower plug in the cubby, but the top-of-dash plug is now ignition based and not always on. this is how it should have been from factory in my opinion. at least there's an option i guess.
I'll give it a shot. Thanks!
John Jensen
San Diego County
Ecodiesel
Hello! I own a 2023 Ram TRX so my fuses don’t go that high. How do I “re-fuse” or move my fuses to fix the issue? Thanks!
I'm not familiar with a 2023 TRX, nice truck. Your manual should show all your fuses' locations and what they serve.
batman900
tx
Thank you for this info!!!! Just got a new truck and was putting my garmin dash cam in. Saved my bacon.
clayusmcret
Moundridge, KS
Hemi etorque
We finally changed 54B this week and the dash outlet finally goes out with the turned off engine. Thanks for the assist!
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
I just did this on my 2024 Ram 2500. It is a slot that allows you to move the fuse from one position to another (3 slots). It is fuse 90/91 located in the attached picture. I simply had to remove the fuse and reinstall it by moving it one “slot” over.
Thanks for this post!!
Adam
