12 volt outlet
Brad L
NC
6cyl
I had a2017 ram that I would have to turn my plug in inverter on connected to the always in port and then start the truck before it would produce power. Now this 2019 does not have a always on 12 v port and I can't figure out a way to duplicate the process. The inverter will turn on but not produce anyone else figured this one out?
kad
Hudson Valley, NY
5.7L HEMI
The '17's don't have the movable fuse to make the 12v port always on?
-K
B
Brad L
NC
6cyl
The 17 always on outlet was in the console. The 19 only has USB ports in the console and only one 12v outlet altogether.
kad
Hudson Valley, NY
5.7L HEMI
Ah, sorry, I missed the bit about it being a '19. Is it a Classic or a 5thGen? If it's a 5th Gen you might want to ask over in the 5th Gen forums. I thought the 19 Classic had the same setup as the older 4th Gens...
-K
B
Brad L
NC
6cyl
It is a 19 classic. I had the same problem with the 17 I had but was able to overcome it with the always on socket. It seems like a strange issue....
