'13 ram 1500 wouldn't start now fires and revs up
Ccravillion
Green Bay, Wi
My father in laws truck is having this issue he recently installed ported throttle body and trinity tuner anyone have any ideas what is causing this currently sitting at car wash trying to start it
Hemi_Express2013
Nantucket, Ma
Not a lot of info with this one, but I think I would start with some of the obvious possible. 1) Did you disconnect the battery when installing the PTB? 2) Is the MAF sensor/TB plugged in? 3) When istalling the TB, hand tight with the screws correct till setted? 4)Throttle blade might have issues, defective from porting, not closing, leaking. Sounds like to much air. Try reinstalling oem TB, see if that fixes the problem.
Last ditch, restore original back up file from the trinity, but I would assume to much air at idle/start up. Let us know how you make out
Jmhm17
Massachusetts
5.7L HEMI
Sounds like your iac is confused or too much air is getting around the throttle plate. Sou ds like a crap port job if you ask me
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Ccravillion
Ccravillion
Green Bay, Wi
He ended up re loading trinity and it started no problems since
ChloeBrooks
