16 ram 2500 gutless
Ramcorvette
Portland Oregon
6.7 cummings
I have a 16 ram 2500. I Have less than 60,000 miles. I have experienced low power. Max boost of 22. I hear no turbo wine. I have a engine code of p262d(sensor reference voltage)
also have a sensor reference voltage “g”circuit Lois have replaced map sensor, mag sensor. I replaced the egr valve. I’ve echeck for boost leaks. I’m thinking actuator or turbo stuck failure. None of my codes point to that. I DO have exhaust brake still! I have so much money in this truck. It’s gutless and could not pull my 42 ft 5th wheel. Any help would be great.
gofishn
Iowa
hemi 5.7L, 345 cu in
fried trubo or some part preventing form functioning properly
Idaho Dave
idaho
6.7 diesel
Same problem, 2014 RAM 3500, 6.7 deleted, code says air leak, new turbo, CAC, smoke checked. at 22#'s boost, pressure starts dropping, turbo starts winding up. Ram air inlet valve is not opening. Could it be a waste gate problem or turbo starving for air???
OLEJOE
N. La
6.7 CTD
Sounds like turbo actuator.
