1982 dodge truck dying
longrifle1757
i am having some problems with my truck it starts fine as long as i pump the pedal a couple of times then start it and let it run but when i hit the pedal again to drop the rpm it sputters and dies i changed the fuel filter but still happens any help would be very nice thanks it has a 318 with a 727 trans
crazzywolfie
under the truck
are you sure your letting it sit long enough before you tap the gas? you may also want to check for vacuum leaks.
NYCruiser
Yonkers, NY
If I am understanding this right, the truck won't idle with the choke off? Idle circuit adjustment, carb rebuild, fuel pump, vac leak, tune up/timing. could be lots of stuff.
