Mike Heimes
- Aug 6, 2019
- 2
- 0
- Location
- Fort Walton Beach, FL
- 1998
- 5.9L Magnum
Hey all! I currently own a 1998 Dodge Ram 5.9 Liter with a few issues I feel are all connected.
It started with cold starting taking about 5-7 seconds for the engine to turn over and the idle was rough when at a stop. When I would take off from a red light it would jump until I got to around 15MPH and then it would pickup and have smooth acceleration the rest of the way through. Wasn’t bad enough not to drive so I went ahead and changed plugs/checked wires, new air filter, ran some sea foam. After all of that didn’t get any change out of anything.
One day leaving a parking lot after shopping I pulled out into traffic and it wouldn’t go above 40 miles an hour and quickly went to 35,30,25,20 all the way down to 10mph and it would go a hair over..pulled into an auto parts store since it was close..took a quick look over of the engine, topped off oil and started it back up..left the parking lot and took back roads home at about 15mph where it’s sat since. Did a little research and have since changed the idle air control valve and Map sensor.
As of right now it takes about 10 seconds to start and the idle is really bad to the point that it just shuts off or just idles terribly. Switching from gear to gear doesn’t change the idle at all.It will only drive about 5mph. I also noticed that when the engine starts I don’t get that loud throaty dodge startup, I honestly can’t even hear the engine running.Only way I can tell half the time is checking the RPM’s or the truck shaking from the idle.
Was thinking of changing the coil, checking for clogged cat, but I don’t want to keep shotgunning parts if I’m not sure it will fix or not.
Any guidance is very much appreciated.Thank y’all so much!
