1999 ,1500 4x4 5.9 .
jimbo684
My break pedal goes to the floor ,no leaks in any of the lines is it the mastercylinder
Sent from my SM-G925T using Tapatalk
whetrick1
The break fluid could be getting past the seals in the master cylinder and letting the brake pedal go the the floor. Did you check and make sure that you didn't have any leaks at the wheel cylinders or front calipers.
Jus10case
