2/4 crown suspension drop
M27
SJ,CA
Also had frt/rr hellwig swaybars,spohn upper and lower control arms,panhard bar and rear qa1's installed but the shop that installed it had a couple problems they couldn't install the front shocks because the lower bolt mount was not long enough to safely install. anybody with front qa1 shock have this problem?
R/T_Fire
Pleasant Grove
I'm a little confused, Please elaborate on the lower bolt mount issue.
I do know when guys started putting QA1's on they were modifying something. Look up some posts from DavidRam regarding the Shock installation, but I thought this issue was solved.
Oh and it looks Great!!!!!
M
M27
SJ,CA
the shock lower mount is u shaped and the bolt only contacts its outer edge and he said it might come off
Ak47bravo
Houston
Truck looks awesome!
How does it drive? Hitting bump stops at all? Are you running the stock bump stops? So you are currently running the stock shocks in front?
I am considering getting the Crown 2/3. ( currently have the Belltech 2/4).
Can you take a picture of your QA1 mounting bracket? I did some extensive reading a while back and never heard anyone saying there was any issue or complication with front QA1's mounting bolt. Like previously stated, when people originally started using the QA1 there was modification needed. However someone found a different QA1 shock that required no modification for install.
M
M27
SJ,CA
it doesnt drive that good since its almost riding on the stock front bumpstops with the stock shocks
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
What part# did you order on those front shocks? The correct number should be 514.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
That should be the correct shock unless QA1 put the wrong T bar in those somehow. I have been running the same shocks in the TR514 version since last year without any problems and know numerous other guys running them trouble free as well.
Ak47bravo
Houston
Matt- Does your front QA1's have the same lower mounting bracket as his?
Depending on where exactly the bolt and nut tighten down on, I wonder if a washer would be able to provide enough contact?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
It looks the same, but all the QA1 T bars look the same.
I have another pair of these on order for a local customer, so I will measure them when they come in early next week.
DavidRam
SoCal - Redondo Beach
2012 RCSB
That is the wrong cross bar, you need the longer one. QA1 has two different crossbars...
Also, I would drill out the factory threads and use the QA1 bolts and nuts...
You need the one that is not installed in the picture below. If you talk to QA1 about it, it is the crossbar that comes standard on the TS801 shocks...
craigsez
Novascotia,Canada
Someone explain to me why they do this mod if the ride is rough...I have thought about lowering mine to give it a faster look but i see folks sayin the ride is rough..
OOPPPPSSSS......Sorry op..Forgot to mention she looks sharp lowered..
THETANK
up jor *** mang
2015 R/T
honest to God my Belltech 2/4 with all of the proper pieces rides just great:favorites13:
M
M27
SJ,CA
thanks guys, i measured the stock t-bar length and its 3.5" and the qa1 is 3" so i ordered a new t-bar kit hopefully with the new bump stops and qa1's installed the ride will be better
Ak47bravo
Houston
Did you ever get new shocks installed?
M
M27
SJ,CA
front qa1's and smaller bumpstops installed and the shop had to retighten the control arms because they were already loose and it now drives and handles pretty good
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Did you end up installing the 514 QA1's after all? I just installed a set on the 2014 regular cab we built last week, and they bolted up without any issue using the supplied T bar that came on the shocks.
M
M27
SJ,CA
yes they were installed after I bought the longer t-bar kit no problems
OasisNinjaBat
