2.5" Front Lift Coils
Hemi Ram12
I was wanting to put 2.5" Front Lift Coils from MaxTrac on my 2012 Ram 1500 Hemi ST 2wd... I wanted to see what ya'll thought of the leveling kit and if i would have any problems with my UCAs and if i would be able to run 34 inch tires on there also....
Thanks
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I didn't use them, but would without a worry, I think UCA are 4x4 issues, so you should be ok, and I am running 34.5" with 2.5" front lift on my 2WD.
H
Hemi Ram12
Okay good that's what i like to hear. What kit do you have on your truck.
Graygoose
Oklahoma
Convert, for now.
small
Just the Daystar 1.5 spacers.
(lifted it level though)
Ram Man
FL
2013 Sport
I have lift coils and just put my 34s on. They fit perfect and look much better
H
Hemi Ram12
So with the lift coils is the front pretty close to level with the back or is it a little lower still then the back
Ram Man
FL
2013 Sport
Every truck is different. Some trucks come with more rake than others. It leveled my truck out but like I said, every truck is different.
H
Hemi Ram12
okay and yea right now my rake is 35 in the front and 39 in the rear so i have a 4 inch difference right now
Ram Man
FL
2013 Sport
Are you sure that measurement is correct? If it is I would go with spindles from maxtrac or cst. It is a 4 or 4.5" lift and will still ride great, just a little pricey compared to coils or spacers
H
Hemi Ram12
Yes i am i had the truck on level ground and measured from the ground to the bottom of the of the outside of the finder wells and that's what it read and yes that's what it looks like then ill have to go with and yes it is a little more pricey then what i wanted
Graygoose
Oklahoma
Convert, for now.
small
wow. Mine was only 2.5" difference.
H
Hemi Ram12
well i wonder why mine has that 4 inch rake to it when most or all other trucks have 2 or 2 1/2 inch rake
