2.5 inch HBS leveling kit is here!!!!
lone12star
Kyle, Tx
so i ordered my leveling kit from hell bent steel last thursday and it came in saturday. i am looking into having a shop install it but i wanted to know if it is hard or not to install yourself. i would really want to do it myself but i just dont know if i would know what im doing and the last thing i want to do is mess up my brand new truck. any advice helps!
4x4Hemi
Edmonton, Alberta
I did it myself and i had no prior knowledge on this stuff.
lol took me a few hours but i got it done eventually. all you need is some different sockets and a torque wrench. its pretty simple really, crowbar helps in getting the coil back in place once you place the levelling kit ontop
TXKID
Houston, TX
I've never installed one before, but a lot of people would tell you to just take your time and don't rush anything. Sorry I'm not anymore help than that...
1500ram12
5.9L Cummins
I installed my rcx 2.5 kit and took about 2.5 hours. What I found out to be the easiest way is to unbolt the upper A arm and take off the brake calipers to give you a little extra room to get the struts back in.
Sent from my DROID RAZR MAXX using Tapatalk
quietpeen
2021 TRX
Hellcat
If you are going to do it yourself I would look into getting a coil compressor
Stroked
Beloit, Kansas
I had to fight the passenger side pretty hard to get the spring and spacer back in and mine was only the 2" spacers. I don't know if I could have gotten the 2.5" in there. Probably would have had to remove one of the A-arms. I tried using spring compressors, but there wasn't enough room.
4x4Hemi
Edmonton, Alberta
It can be done guys its not bad at all as long as you use a small crow bar and slide it in. It actually goes in easy if you have one person pushing down and one using the crow bar. I dont think you need the comoressor
redsand
Spearfish
3.5 Ecoboost
I also did mine and just used the crow bar method, its a pretty straight forward install. I did fight the passenger side as well but got it all in in about 4 hrs but I also had to keep an eye on the kiddos so there were a lot of breaks haha.
Just helped my father in law with a 2.5 on his 2500, that we absolutely needed the spring compressor for.
Williamw454
eastern, CT
I did one on my buddies truck, it's not that bad.. If you get a spring compressor, the Harbor freight ones are like 20 bucks and work good.
lone12star
lone12star
Kyle, Tx
well i found a shop that'll do it for $125 so i think im gonna have them do it tomorrow on my day off and get the alignment done as well or next week
lone12star
lone12star
Kyle, Tx
how bad would it be if i waited to do the alignment for a week or two?
4x4Hemi
Edmonton, Alberta
Depends how much you drive haha. If you only drivr a couple hundred miles it won't be terrible but if yoi do like 1000 miles it will br bad
lone12star
lone12star
Kyle, Tx
i only drive about 10 to 15 miles a day if that, i live10 minutes away from work
steadly2004
Lowell, NC
CTD 6.7
Try not to go more than a week. At those miles its not too bad.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Black Cloud
Oxford, PA
I had to drive to a job first thing in the morning that was about 60 miles away, so by the time I got the alignment done I had about 110 miles on it. It was way off when they did it but I didn't notice it while driving. Just wish I didn't have to drive that far that morning.
lone12star
lone12star
Kyle, Tx
Well the shop is going to install it next week so next week it will be done
Arctic-Rodz
RGV, TX
6.7L Cummins
you don't need a spring compressor to install that spacer!
you just drop the strut assembly. 3 bolts on top and the solid one on the bottom.
I took the top spindle nut off, top sway and tie rod bolts off for space.
took my brother and I about 2 hrs for the complete swap on the driveway.
Making hole
2012 Ram S/C
What size tire can you run on stock wheels with a 2.5 inch on a 2012 1500?
Sent from my LG-E980 using Tapatalk
