2000 5.2L Magnum stalling problem
Mantyl
Silsbee,Texas
Magnum V8 5.2L
Problem started with truck stalling at highway speeds, restart and go. Times between restarts grew. Changed pickup coil,crankshaft sensor(torture),IAC,MAP,TPS,PCV. No fix. Sent PCM to SIA Electronics for retooling. Same problem. SEnt it back. This time the problem seemed to be solved, EXCEPT when I shifted into reverse; the rpms would be sporadic and go dead. Any help much appreciated. This is a 2000 5.2L magnum.
rrb6699
Orlando FL
I'm having real problems (other post) with crank sensors. I've replaced 3 this year and I think it has to do with incorrect voltage overloading the sensor. if you figure it out (or I) let me know what the cause is.
Try changing the crank position sensor again. yes, blind job and cit fingers I can't wait. mine just blew AGAIN tonight thankfully as I was turning into the driveway. but not happy.
it's a good thing I can do this with my eyes closed. tip: get a piece of plywood and put it across the front of your engine compartment so you can lay under the hood. a little easier but not much. oh, remove the oil dipstick before you put the plywood up. otherwise it will bend/break it.
ray
crazykid1994
Need to trace through the wiring. Sounds like could be losing the signal for something. Not much help but just throwing ghat out there so you don’t think nobody is seeing you.
M
Mantyl
Silsbee,Texas
Magnum V8 5.2L
ray
Thank you.
