2002 Ram 1500 Fuse Locator
adamh3844
Harrisburg, PA
4.7l
2002 ram 1500 QC 4x4 SLT rear driver side door lock does not work. Must manually lift and push down. Replaced Lock Actuator and had no change. Besides wiring was wondering if the fuse could have anything to do with this problem and if anyone knew what fuse it would be.
Fuse Location: 29 Fuse: 10A
Bus Communications, Instrument Cluster, Navigation/Telecommunications (Hands Free), Power Door Locks, Transmission Control System (Electronic Transfer Case/Power Wagon)
I was not sure if this was correct found online
If it is wiring not sure where to even start.
Off Topic
Rear Passenger Side speaker does not have power attempted to use other speaker and had no luck. Would this be Amp or Wiring most likely?
Better off just replacing Stock system and buying new one or trying to tear into the wiring?
alphaprojects
