2003 5.9 Trans Cooler
RamYourDaughter
2020 Classic
Have a 2003 2500 with 5.9 and the 48RE transmission. Found the cooler lines to be leaking so I will be replacing them and bypassing the heat exchanger on the block. I have found a Mishimoto direct drop in but it is 500 plus. I don’t believe the doorman replacement will be sufficient . Does anyone have any recommended direct drop ins ?
Connie Mack
LA MARQUE,TEXAS 77568
5.9 Diesel
not sure I'm talking bout the same but on my 03 ram 2500, my mechanic found trans cool lines leaking. instead of me spending a ton, I replace the entire set of lines with high pressure 3/8" hose. with clamps. doesn't leak now. transmission cooler lines do nopt create high pressure, so hose that has 300psi/400 degrees will be perfect.
