I bought an 03 ram 1500 4.7 4x4 with no engine, but i had everything for it except the short block. I bought a block, it had smooth bores no rust and the guy said he put new rings in it.
I put it together with new head gaskets and new head bolts. torqued the heads to spec. * the heads i had were from a different engine, appeared fine * put it in the truck and started it up .. sounded good, but gradually started smoking.. and i mean it was churning out the smoke. bluish smoke.
I did some research on causes.. and figured it could be the valve stem seals.. so i pulled the heads and changed those. put it back together, torqued everything and same deal.. smoking LMF.
I'm thinking maybe the cheap amazon head gaskets i bought are not right? or maybe a cracked head or block... i cleaned up each head and the block surface and saw no cracks... but still i wonder.
Next i plan to take the plugs out and do compression test on all cyls and maybe get a borescope camera i can peer into the cylinders with .. maybe see something?
Hoping someone here can offer some advice on if something different i should be trying?
