2004 Ram 2500 EGR valve, (missing?)
Toby West
Williamsburg, Va
im getting a code P0403 and P0406 says EGR valve, easy fix right? (arent they all). Only I go to dig into it and well no EGR valve.. I can't find information or videos showing a second type of EGR set up? can anyone assist?
HemiLonestar
Navy Badge Coast Guard
MD
3rd gen 2500/3500 hemis didn't come with it lol...curious that you're getting EGR codes when it's not even in the PCM.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Like HemiLonestar said, no egr valves on early 3rd gens. Very weird that your getting those codes. Hmm. Any chance you have access to a decent scan tool that does live data, programming, etc? That’s what you’ll need to figure this one out. Or try to find a shop that knows dodge trucks, not the stealership though! Unless you want to be overcharged.
HemiLonestar
MD
Only the 03 and the HD's, starting with 04 half tons they got EGR.
chrisp2493
Always Modding
Warren, OH
392 Hemi
Did somebody change out the computer/pcm? That’s about the only explanation
I Bleed Ram Trucks
HemiLonestar
MD
I Bleed Ram Trucks
Or if the pigtail is part of the harness and just connects to a dummy on the engine and moisture or something has gotten into the connector.
Toby West
Toby West
Williamsburg, Va
yeah, this one has me quite confused. The codes are P0403 (Exhaust Gas Recirculation Circuit Malfunction) and P0406 (The exhaust gas recirculation (EGR) sensor A has high circuit voltage).
Toby West
Toby West
Williamsburg, Va
i will check the connection and the dummy. Should i just replace the dummy and what's it called so i can buy one. No one can seem to tell me what its connected to. lol.
Gordon Gillan
California
Curious if anyone knows if the 2007 2500 HD Hemi also did not come with an EGR? Just bought one and had to have it smog tested, (California). It passed the computer scan but the technician failed the truck because the EGR and tube was missing. There's clearly a blank-off plate on the engine and plug in the intake but I can't find any signs of the wires/plug harness. What proof could I show the smog shop that the truck came stock without the EGR? Or, if it did, where would I look for the original wiring harness so I can reinstall the missing parts.
dterrel
