2005 brake issue
Harb278
Tennessee
4.7L Magnum
I have a 2005 Dodge Ram 1500. Regular cab, RWD, manual, 4.7L engine. My left front brake was squealing constantly so I checked it and the pad had worn a gouge into the rotor. Ordered 4 new rotors and pads. I took off the left front caliper and the boot was torn. Ordered new calipers.
Put new rotors, calipers and pads on. Bled the system. No brake pedal. Bled the system again. Still no pedal.
Put new reservoir and master cylinder on. Bled system again. Had to refill reservoir twice doing this. Still no pedal. Tried the electronic reset. Says system is not supported. Checked brake hoses, all are solid. Still no pedal. No leaks anywhere.
I can get it back but have to pump it up to get it. About three inches of play before pedal starts to feel stiff. Let sit for a couple of seconds and no pedal again.
Looking for any and all ideas, suggestions on next step. Trying to avoid paying someone $2500 to turn one screw or kick a tire and get everything back. Haha!
HemiLonestar
Navy Badge Coast Guard
MD
Bleeders installed up?
ABS pump bled?
Did the master cylinder get too low/go dry at any point?
Is the vacuum line to the booster still connected?
H
Harb278
Tennessee
4.7L Magnum
Bleeders - yes
ABS - can’t take it out on the road to do so MC - only when I installed the new one
Vac - yes
HemiLonestar
MD
Oh lord....ABS is electronic bled, not road bled.....smh
Did you bench bleed your new master cylinder....?
H
Harb278
Tennessee
4.7L Magnum
I used an obd II on the abs, it read that system isn’t supported.
No I didn’t bench bleed the new master, but I’ve probably bled about a gallon of fluid through it since it’s been installed.
Timkll
