2008 2wd level or lift kit
SD38-2
Indiana
I've been looking for a leveling kit or mild lift for my 2008 2wd 1500 Ram. I've done some research and seen some like the Ebay spindles because they don't change the suspension geometry. I've read coil spring spacers can cause issues with ball joints and require longer shocks. Originally I was thinking of installing a 1.5 inch spacers on my truck, now I am considering the lift spindles. I would like some input and opinions on both.
Also which companies make a nice mild lift for the 06-08 1500 2wd rams?
LS5DodgeRam
South Florida
4.7L v8
any type of lift or change in the geometry of your suspension will mess up the ball joints... dodge ball joints are notorious for doing this.. if you do any kind of lift kit i suggest replacing the balljoints as well to start fresh. after so long of the same wear pattern then to change it and add new stresses to them will mess it up no doubt about it.
LS5DodgeRam
South Florida
4.7L v8
Someone was looking to do lift spindles and I recommended replacing some other parts while he already will have everything apart, if you want I can pm you the information that I presented to him.
