2008 5.7 not starting cranks 1/8 turn
D
Donben
Alberta
I will try testing voltage thanks.
No problem updating, thats best way to make these forums work. Hope one day it helps someone else out with simular problem.
Btw. The dealer had over $6000 quote of work they said my truck needed! Not cool. $3700 was to change tipm and transfer case shift motor. Cost me a few hundred to do myself, crooks!
Karlsweg
SW Florida
Try jumper solenoid with a screwdriver. If it turns over more than likely it’s a grounding issue. Clean ground surfaces where it hooks to block and battery. I bought a ground kit and it solved the issue for me. The parts store cables are too small in my opinion. Good luck
Arturo Rojas
