theskyisoutthere
I know there is a lot of similar post s but I need some guidance checking what else I need to check.
I bought a very used 2008 ram 1500 4x4 cheaply to help my neighbor, who was having money issues. It has only the one issue misfire on cylinder 4 (p0304) and also (p2311) Ignition Coil 4 Secondary Circuit Insufficient Ionization, which is probably the source of the 0304.
I have other 5.7 vehicles so I had an extra known good coil swapped it in and new plugs matching the old ones, no change, also then swept coils cylinder 4 to 2 and 2 to 4 no change still misfire 4. Pulled injectors swapped 4 to 2 and 2 to 4 problem stayed at 4. Also each time cleared codes and they return as well as the th feel if the miss. Engine is dead quiet no ticks and was previously replaced many years ago. Also many other circuits have been mended but this one seems left alone.
I have also pulled a test light and can't get a light from the coil to ground (was told to test this but not sure the procedure. Tried multimeter most I got was a few volts. Went to harness at PCM and tested circuit to coil from PCM and it has good continuity no sign it has shorted wiggled and nothing changed.
When I do put it all back right it seems like when I reset the code it starts up on all 8 for a few seconds before ejt goes back to misfiring.
Again I bought th truck this way knowing the lack of rust was worth trying to fix it.
Any help would be appreciated, also if someone had skills and time to walk me through it all in a call I would be willing to pay for time.
I can't locate the test parameters for the coil and circuit tests for this. If I this is the PCM I would be happy because I am dreading it being lifters or cam. Lots of miles on body but no idea total engine miles. No ticking infact I had a charge rwith a 5.7 that ran great and was louder than this is even with it misfiring.
