calegustafson
Without warning P2262 code popped up on dash after a warm start, just move the truck. I tried to drive the truck after to no avail. I have no boost pressure whatsoever, it wont get over 20km per hour and will blow fat black smoke. I have read the code to be no boost pressure so I checked around the air to air for cracks or leaks, unplugged sensors, checked air filter blockage, and the turbo wheel. Nothing that I can see from a basic inspection screams “I’m the issue”. I can’t drive it to my shop to do more inspections so I’ll have to haul it on a trailer if I want to get deeper in to this.
Does anyone have any insight on other methods to check and possibly fix this issue. I assume the turbo is shot but better to check than to spend 5k for the same issue to arise.
