2008 Ram Harness
Adam Foster
Canada
Hey all, I'm replacing the factory radio in my 2008 Ram for something with bluetooth. My ram doesn't have the infinity system, or nav, or steering wheel controls... pretty basic. My question is, do I need to spend money on the PAC interface kit, or should I be able to get away with a standard harness??? I'm replacing with a single din inexpensive JVC radio. The factory radio has the two separate connectors (one large one small).
Thanks in advance for the help.
HemiLonestar
Navy Badge Coast Guard
MD
If you don't have any of the peripherals you shouldn't need it. Check with your radio manufacturer.
justin13703
MD
Being that it’s an 08 the radio is turned on and off by the canbus system. That’s why the harnesses are so expensive, because they have a little box that basically talks to the canbus system in the truck.
It is usually possible to use one of the standard, cheapo harnesses, but you will have to grab 12v accessory power from another source. Usually from the cigarette lighter that comes on and off with the key.
A
Adam Foster
Canada
Awesome, I figured I could use a cheap harness and steal power from the lighter. Thanks for the reassurance.
anitamack
