mikehutch
2008 Ram Quad McGaughy's 2/4.5 kit install
Well today I began the installation of the drop kit. Some of my photos didn't come out so I'll probably do some ninja edits to get them inserted. Pay no attendtion to the dates on some photos, the camera was off. Quite a feat to take a pic of a 2008 in 2004.
So I did a pre-measurement:
------------Ground to top of wheel opening Center of wheel to top of wheel opening.
Front Left ----------37----------------21.5
Front Right ---------36.5--------------21.25
Rear Left------------39.5--------------24
Rear Right-----------39----------------23.5
Truck had a bit of a lean.
First to get the Ram in the garage.
I started with the front. After getting truck on stands and wheels removed.
Removed the shock, and stabilizer link...note the use of PB blaster to help smooth the way.
I started off trying to pop out the lower ball joint from the spindle but was not very successfuly. So I moved on to the upper one. I had a puller I was able to use like a ball joint press to pop this one out.
You can now drop everything down. The spring doesn't just come and will need a little encouragement and is still slightly compressed. But a good crowbar will pop it out.
Here's the difference. (Springs upside down in photo so that would stand up)
Now put the isolator on the top of the new spring and start to reverse the process. This will slip in with little effort due to the shorter height.
While in here I also installed the Moog Alignment kit. After looking it over not sure it does too much but I already bought it so I installed it. This installs on the front upper control arm mount. Hopefully there will be plenty of adjustments to allow the shop to get the alignment right on.
Well I'm still working on the rear and plan to paint the calipers before a final button up....so stay tuned.
