2008 Ram Quad Painted Calipers
mikehutch
New Boston, Mi
Ok so while in the project of lowering my truck I also decided it would be a good time to paint the calipers. I picked the G2 kit off of ebay which was a two part system and I went with red.
So first steps was to get everything clean. Luckily this truck was in great shape and things were pretty clean.
I have a bead blaster so the brackets were pretty easy.
The calipers took some brake cleaner, wire wheel and elbow grease.
Apply paint and reinstall
And the finished product
When I first started this project I thought there wouldn't be enough paint to do all four..even though it says there is. Well there was more than enough and I was quite surprised at how much was left over.
So what do you do when you've been sniffing paint fumes and are watching paint dry........paint more stuff:
And more:
While the chrome rams head came off pretty easy, it certainly wasn't meant to go back on while the plastic backing was still on the truck. So I had to remove the platic piece, give it another coat, reinstall rams head and then stick it back on.
If I had known I was going to have the extra paint I certainly would have prepared more items to paint. But the paint was getting thick and I didn't have the time to pull items off to clean......but if your going to start a project have some extra things just in case. :)
quietpeen
2021 TRX
Hellcat
nice work....you def. got the brackets much cleaner than i ever did...LOL
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
looks good
mikehutch
mikehutch
New Boston, Mi
Yeah, I picked up a harbor freight bead blaster a number of years ago. That was probably one of the best investments in my garage. I bead blast a lot of things when working on the cars. Many times just the bolts and nuts....then of course a dab of anti-sieze. :)
BigH0ss
Banned
Came out good I did the same
noraa73
