2011 Dodge ram 1500 5.7 hemi Few issues need some help
jws123
nj
So i just bought this 2011 dodge ram 1500 big horn 5.7 with 188k on it REALLY CHEAP... paid 5k for it truck is in decent shape. So the guy i got it from couldnt get it running noticed no fuel pump so found out the TIMP fuel relay is bad so i jumped it out truck now runs. What is the best way to fix this? any way to bypass it? i mean now i have it hooked to the rear cig lighter circuit but its annoying every time i have the key on it runs pump. I am getting conflicting answers if i find a truck that's the same package or a matching box with same numbers i should be able to plug it in without having it programed correct? I also thought about replacing the on board relay myself but figured if i messed up i would have nothing.
Also i noticed now that the thing runs the fuel pump makes some noise its louder then my other ram its loud overall but sometimes makes a high pitch squeal then goes away i assume its going bad?
Another issues it has the all to common exhaust manifold leaks both sides bolts broke gasket blew out does anyone know of a better aftermarket gasket? the one they sell in auto parts store looks like **** metal with gasket on top... what ever happened to a solid gasket its like its made to corrode/rot out.. i used the same one on my 09 and it blew out already...
Wahrsuul
Central S.C.
From what I've read, it's not the gasket that the issue with the broken exhaust bolts, it's the manifolds. Most people that have gone to headers - either shorties or long tube - say they haven't had an issue since.
jws123
jws123
nj
i replaced bolts and warped manifold on my 09 same engine and 1 side blew out im going to look into headers manifolds/gaskets seam to be trash also noticed a small knock when hitting gas timing chain looks to have a lot slack so replacing it hopefully that was it.
AS far as the TIMP i have decided before i spend the money on a replacement i am going to try myself or have a local tv/computer place solder in the new relay and hope it works.
ColdCase
In 2011 and most years, you can swap in any TIPM part that is the right part number for the truck. The truck configuration is stored in another module, PCM I think, and gets downloaded to the TIPM.
FCA recalled Jeeps of that era to install an outboard fuel pump relay. I think the best functionally is a TIPM replacement with the most current rev level available, but then there is that cost.
Lee Peterson
Hamilton ON Canada
RLJ10X
Southern Indiana
Shortly headers aren’t that expensive. Why bother milling those junk iron manifolds.
Matt at Moe’s can get shortys, gaskets, and bolts.
jws123
jws123
nj
Ok i cheaped out and sanded the manifold flat didn't want to pay $250 to replace both it was a ***** to get the broken bolts out ordered the timp relay going to try to fix it myself they wanted $200 to solder on 1 small $8 relay lol
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Let's see some pics of your $5K truck. Sounds like you got a bargain. :waytogo:
jws123
jws123
nj
EDIT.
huntergreen
Like the color ! Any idea if it ever dropped a liftr? Original cam ?
SYKRAMMAN
Banned
Jersey shore
06 Mega
Dam nice truck for 5k brother, I wouldn’t care what was wrong, even a blown engine, I still would’ve bought it. Nice find!
When I was working on my truck, it had the same tipm problems, tried finding someone who fixes them but couldn’t, but as I see now that they do exist, of course I find this out 5 tipms later, lol. O’well she’s sold anyway.
jws123
jws123
nj
Engine is currently making a slight knock noise doing timing chain at the moment had a lot of slack hoping that's it if not will flush engine a few times but most likely see lifters in the future. Looks like orig cam and lifters as the front cover was never taken off soo...
jws123
jws123
nj
Noticed it says your from the jersey shore thats where i bought it :rofl:
rwreuter
I don't see the picture
jws123
jws123
nj
Welp truck needs lifters RIP guess its expected at 188k so now my question is whats difference between MDS and NON mds lifters? i can only seam to find NON MDS when looking up lifters? and how do i tell if my truck has mds i haven't had the chance to drive it yet dut to its issues so i have no idea if it does.
Lee Peterson
Hamilton ON Canada
All ram 2009up 1500 hemis Have MDS. MDS lifters have holes in the body to bleed oil pressure to keep the valves from opening while in 4 cyl mode.
I found a few sets on ebay:
https://www.ebay.ca/itm/Dodge-Jeep-Ram-5-7L-6-1L-Hemi-MDS-Valve-Roller-Lifter-Set-Lifters-Guides-Bolts/252748772987?hash=item3ad900367b:g:VH0AAOSwfVpYpKKT&_sacat=0&_nkw=mds+lifters+ram&_from=R40&rt=nc&_trksid=p2380057.m570.l1313.TR1.TRC0.A0.H0.Xmds+lifters+ram.TRS0
https://www.ebay.ca/itm/05-14-Dodge-Chrysler-Ram-Jeep-5-7L-6-1L-OHV-HEMI-MDS-Lifters-Complete-Set/302025957142?hash=item4652265f16:g:8tcAAOSwH3NXm5is&_sacat=0&_nkw=mds+lifters+ram&_from=R40&rt=nc&_trksid=p2380057.m570.l1313.TR1.TRC0.A0.H0.Xmds+lifters+ram.TRS0
jws123
jws123
nj
Ok thanks for the info Still sucks i gotta pull the heads Hoping the cam is good tho it runs good just makes nasty noise when your hitting gas and slight tap/knock at idle Almost sounds like bearing but its not i know what a bearing sounds like:banghead:
