2011 ram 1500 Transmission Lines
jws123
nj
2011 ram 1500 5.7 5 speed auto trans both of my transmission lines are leaking where the metal lines turn into the rubber line leaks around the metal crimp connection. Has anyone found a aftermarket replacement? or solution to stop the leaking? I was thinking about cutting off the metal crimp with a dremmel and clamping both it kind of does the same thing?it will clamp it tighter. New oem lines are like $200 that is way to much for a oem line that will leak again.
Lorz
Humboldt Sask
Where I used to work we would cut out the rubber sections and go to a
high pressure hydraulic supply store to have new hoses made up with
compression fittings. After these were installed never had any problems
with leaking. I believe the diameter was for 3/8 inch tubing.
Reticle918
