2011 Ram 2500 Crew Cab 5.7 windows / door locks inop
peter cain
denver, co
Hi Folks,
I have a 2011 Ram that I can't get the windows or door locks working. I have new door modules, new driver's master switch module thingy, and power and grounds to both units. I have 2014 doors, by the way - they came off a 1500 sportsman. The pinout wiring for both doors are the same, as far as I can tell, so that *shouldn't* make a difference. This is a new / custom installation that has not worked yet. I have connectivity to the CAN network too. I can open and close both rear windows from driver's seat, but that's it. No door locks, no driver or passenger front window control (even from the passenger side). I am looking for suggestions on what to check out next.
Thank you
markusaf81
following...I cant operate the rear windows from the drivers seat but the locks and mirrors work fine ...
P
peter cain
denver, co
I can tell you that the rears are much more straightforward as far as wiring goes. Chances are, you have a broken wire somewhere. This forum is not useful for technical matters (not for me anyway). If you want to know what plastic ****** or spinner rims to buy, this is the place. But, for matters of any additional importance, head on over to www.ramforumz.com. Those guys are not terribly bright either, but at least they'll try to help. This particular issue about the rear windows is discussed in detail in several threads over there. Good luck!
dterrel
