2011 ram 3500 2wd 4wd issue help.
i1ya
Seattle, WA
Hello, I’ve got a 2011 ram 3500 crew cab auto 70k miles. A quite but noticeable thumping sound has came up on my ram starting from about 30mph and increases as I go faster up to 70 and goes on while in 2wd. But once I put it in 4wd things go butter smooth and the sound goes away, but once in 4wd when I accelerate and let go of the petal I get a different grind sound that comes and goes away quick. Any ideas what it could be? Please help. Ive replace ball joints, all U-Joints, center bearing, and wheel hubs, shop has inspected my differential fluid and transmission oil all checked out good. The sounds I mention are louder some days and sound really bad and quite other days. Running deletes with minimaxx along with the transmission tune.
jws123
nj
Go outside yourself or watch someone do it check your rear and front diff fluid shops are lazy sometimes make sure its not low also check your transfer case fluid.a Also jack truck up and check all front hubs/rear for movement.
