grinding noise
  1. Jameski
    Grinding and Locking After Replacing EVERYTHING with no Answer in Sight!!
    Hello! I’m new to the forum and just bought my first Ram last month (2018 Big Horn 1500, 5.7 Hemi 4x4). I am completely stumped and going out of my mind about an issue I’m having with my brakes and couldn’t find any other thread covering this so I hope I didn’t miss one. A few weeks ago, we...
  2. SugaryClapz
    Grinding noise coming from the engine bay when hard accelerating at 5-6k RPM
    I been trying to figure out what is making a grinding noise in the engine bay when I am at 5-6k rpm. It only happens when I accelerate hard and when it is about to shift to the next gear. I looked on Youtube for videos and forums but it seems nobody has the problem I do. Any help would be...
  3. Mack93
    Starter grinding flex plate teeth
    I have a bone stock 2021 ram 3500. 6.7 Cummins H/O hooked to a Aisin transmission. Truck has 162k miles. Original starter solenoid went bad. Had it changed out. 3 days later on a cold start I heard a grinding noise and truck wouldn’t turn over. I new what it meant. Towed the truck to a shop...
  4. C
    Loud Hum and grind sound 2014 ram 1500 4x4
    Looking for some help to diagnose my truck. I have 2014 ram 1500 Laramie 4x4 and been experiencing a loud hum and faint but noticeable grinding sound that sound like is coming from the driver side wheel and slight vibration in the steering wheel and gas pedal . I thought it was my wheel bearing...
  5. S
    Dull grinding / rubbing noise when braking
    I have a '17 1500 Hemi. Recently I noticed that whenever I apply brakes I get this dull grinding noise, I can hear it on the front left tire area. So naturally I assumed I needed new brake pads. Yesterday I installed the new ones, took the truck off the jack and had the same issue. So now it has...
  6. winters174
    grinding noise from acceleration from dead stop
    I have a 2003 Ram 1500 with a 5.7L in it. I've recently noticed a grinding noise when accelerating from a dead stop. Can't tell exactly where it is coming from but I think it could be coming from the transfer case or the differential. If anyone has had this problem or knows anything it would be...
  7. i1ya
    2011 ram 3500 2wd 4wd issue help.
    Hello, I’ve got a 2011 ram 3500 crew cab auto 70k miles. A quite but noticeable thumping sound has came up on my ram starting from about 30mph and increases as I go faster up to 70 and goes on while in 2wd. But once I put it in 4wd things go butter smooth and the sound goes away, but once in 4wd...
  8. S
    4x4 Low problem
    Hello, I've got a 2013 Ram 5.7L with 62,000 miles. I have had an issue with 4x4 low twice with the same issue and I'm hesitant to switch to 4x4 low again to video it at the moment. I can switch into 4x4 High and out of it no problem. I can switch into 4x4 low no problem. Both work fine. I have...
