2011 ram
Wrencher
Millington, tennessee
Hi folks. I have a 2011 ram 1500 slt, wondering if anyone has had any success with fixing tpms reading flatline issue.
Also need to know if door mirror light pod can be replaced by itself, or if mirror had to be replaced. I much appreciate any feedback.
Wahrsuul
Central S.C.
Not sure what the TPMS issue you're having...
On the mirror, are you talking about the lights on the bottom - puddle and turn I believe? Yes, I knocked the lens off mine and got a replacement online. There are a couple videos online that'll show you how to reach under the mirror to get the clips to remove the current piece out.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
While we have a lot of members who don't own 5th gens posting in this section, you might want to post these questions in the 4th gen section for better visibility to other 4th gen owners.
Wrencher
Wrencher
Ok
Thankyou for info, i am going to get replacement puddle light and fix. For the tpms issue, bought truck used 4 months ago no issues untill 3 weeks ago. Service tire pressure system appeared on evic screen. Went to tire pressures to check and saw left rear had no reading, just 3 short dashes. Shortly after it returned to normal, but still does it intermittently. I suspect sensor is ok, not sure what to check since this is the first truck I've owned that is this advanced electronically. Any advice i can get is greatly appreciated. Thanks.
Jeepwalker
WI
2012 Reg Cab, 4x4
Pretty sure I read you can disable TPMS using AlfaOBD. You might type that into the search feature. It's come up before. But I haven't personally done it so...do a search.
If you see a post in the wrong forum or accidentally post a thread in the wrong forum, just click the report button and note that it's in the wrong section, a forum moderator can move the post.
Wahrsuul
Central S.C.
Most of the time, I'm just viewing "new unread posts" and not really looking at where they're posted.
If it's just one of the wheels that's causing that issue, I'd suspect the wheel sensor. No telling when (or if) it's been replaced.
CamperMike
Peoria, IL
Bad sensor is the likely tpms issue. When they fail it is often intermittent. Happened that way with my old minivan. And with an older gm vehicle I had.
Wrencher
Wrencher
Thankyou all for your help. I'm going to replace sensor. Since last post, found another issue. Front right tire reads correct pressure but as it warms up it reads 2 to 3 times correct pressure. Checked tire with pressure guage and is correct. Any idea why this one reads 85 psi? Thamks.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
You use a hand held air reader and check that way? Sounds like your TPMS has a bug or two. I swap tires and rims often and have had my sensors go into “winter mode”. Mine read after they warm
Up, however the light stays on and once in awhile they will read “- - -“
Wrencher
Wrencher
yes, use a digital pressure gauge. I'm going to do some more digging around. Hopefully I'll find issue. This truck is really nice. If i can get a few bugs worked out, it will be super nice.
