They come off my 12 which has a build of 4/12
Whats the difference beweetn the 12's and the 13's? Is that when they switched to projectors?
Yes that is when they switch to projectors as well. But the lower model '13+ trucks still have quad headlights.
There's a small difference in the shroud design and the beam pattern on the low beams. The '13+ quads have a better pattern that doesn't scatter quite as much and actually has slightly better light output.
Here's the two side by side:
2009-2012 quad:
2013+ quad:
I have an '09, will I need to change anything to get them to fit?
If not Ill take them
They at a direct fit
