You can get at the oil filter from the front real easy. I just roll under the truck from the front and reach over the crossmember. I tried a couple of the tricks for catching the oil, but they didn't work well for me. I just take the filter off, dump some of the oil out, and then take it out. I just wipe up the oil with a rag or 2. To me it's not a big deal, but I understand why it ****** some peope off. Make sure the gasket comes off with your filter too. I haven't had that problem yet but it seems somewhat common.
I only use Wix oil filters
If I recall NAPA Gold filter are made by Wix also.
I try not to use Fram my self I normaly go with OEM or NAPA Filter only.
Just changed my oil at 1400 miles and the gasket stayed on the block. I didn't know it and screwed on the new filter - it distorted the old gasket and when I started the engine, oil went everywhere. Make sure to look for that gasket!
