2012 RAM 1500 RKE not working
theblackduck87
Clermont, Florida
6.4L SRT8 HEMI
I accidently posted this where I didn't want to. I tried to delete it there but it was giving me issues.
I'll let the chips fall where they may for 2x posting.
I've been reading alot about the WIN module in my truck and have come to the conclusion that there are far too many sketchy electronic components for my liking in this vehicle.
I've posted about this a while ago and things have gotten worse in some areas and better in others.
About a year ago give or take a month I purchased new tires and within a week started having TPMS problems. (left rear) This eventually cleared up once I lowered the over-inflation level that the tire technician placed them at.
around the same time I started having Intermittent function of the Integrated Key Fob Transmitter. Sometimes I could unlock the truck on the first click, other times I had to press the unlock button several times. And yes I changed the batteries in both FOBs and there was no change in the reliability of function. When inserting and turning the FOB the truck starts just fine, shuts off just fine, and recognizes both keys.
Recently the remote function has ceased altogether. I hooked my scanner up to the truck and looked at the WIN module. I verified function of the module and the recognition of both keys.
Whats not being seen is the FOB button presses. Nothin' I've got a few more things to investigate before giving up and getting a new WIN.
It should be said that I have an aftermarket remote start module installed and I'm going to remove it to see if that had or has anything to do with this issue. I only hope that if it is causing this problem that it didn't burn the RF function out.
Any opinions? questions, Comments?
theblackduck87
theblackduck87
Clermont, Florida
6.4L SRT8 HEMI
Update. I ordered a cheap RF keyfob checker from Amazon....Checked my fobs...the one in question does not transmit. Checked FOB #2 and it did not transmit at 1st either but after a couple of tries it started to transmit a signal. ( checked the tester with a known working FOB ) Took it outside and tried it on the truck.....No worky...Tried again and the truck unlocked and then it locked with the press of the lock button. Tested #2 ( oh grow up..But poop jokes are funny) from inside the house again and now it actually reaches the truck from inside the house....Go figure.
Not a bad $36 investment to save me $500.
Key FOB 2 is now in play and FOB 1 will be getting a thorough cleaning, testing and possibly a new case.
wanzi ngulube
Zambia , Africa
5.7 hemi v8
Subject: Enquiry on Steering Rack Conversion – 2011 Dodge Ram 1500
I hope this message finds you well.
I would like to enquire whether you are able to convert or supply a right-hand drive steering rack for a 2011 Dodge Ram 1500. The vehicle is currently right-hand drive converted, and I am seeking a suitable steering rack solution, either through conversion or compatibility with an alternative model.
Could you please advise if this is something you are able to assist with? Additionally, I would appreciate any information regarding the process, availability, and estimated cost.
For your reference, please find the chassis number below:
Chassis Number: 1D7RV1CT7BS687852
I look forward to your response.
Kind regards,
Kamikowski
