2012 Ram 2500 Hyper flash blinkers with leds
dalbrecht
Sparks, NV
6.7 L 6-cylinder diesel
Using alphaobd to set "Vehicle Config 4: Rear LED Stop, Tail and Turn Lamps Present for RT" to present but setting is not being saved. Says procedure is completed. For some reason this setting is not being saved. Blinkers will work correctly for a few blinks and then start hyper blinking and get error message that rear turn signal lights are out. I'm hoping someone can tell me if I'm doing something wrong.
DILLIGAF
Canadian Forces
Canada
When I built my flatdeck on my 2012, Had this same issue . ended up just tossing in resistor. Problem solved.
