2012 Ram mystery dial
Mattmattmatt
Oregon
6.7 L Cummins diesel
Anyone know what this dial does? It’s in the center console below the 12v plug. I have changed it while driving and don’t notice a difference and the truck isn’t wired for subs/amp. Any help is appreciated.
jawzs2
Air Force
South Jersey
That doesn't look factory, I'd trace the wires and see where they lead to. If you picked it up used, my bet would be nowhere, previous owner probably removed whatever it was before trading it in.
Taylor513
Phoenix
Yep that's definitely not factory, looks like a bass volume knob but I could be wrong, would just be my guess. But I agree who ever installed that probably took what ever it went to with them
csuder99
If that's a rotary switch it probably was controlling a tuner for the Cummins. E.g. Stealth has a design like this.
NJMOPAR
Older and faster
ELizabeth, NJ
That's the super-rare special order Stealth Dial Shifter for the 545RFE.
The console stick is just for show.
Addicted2fishing
Durham region
HEMI 5.7
Hi Matt! If that is your real name...
That’s for the flux capacitor. Set it carefully between 4-5 somewhere in the middle but closer to 5. Go to 88 MPH (safely) and bring me back an almanac from the year 2046.
Thanks
60% of the time it works every time!
Jimmy07
Looks like the CSP5 switch for shift on the fly tunes. You can see the 4 and 5 broke off. Is the truck deleted?
bdc2
Ks.
There is a rotary throttle control, like a pedal commander, that looks kind of like that.
nick heilman
West Bend WI
Did you buy it used? Looks to be a tuner dial for EFI Live or something along those lines. Turn it to 1 and floor it then to 5 and floor it. If it has a tune it will make a difference! lol
Gear Jammer
Yacolt WA
Cummins
As some of the others have said, that is a switch for changing tunes. It looks just like the DSP5 switch that is used for EFI Live tunes, other tuning platforms may use the same switch. If your truck isn't currently tuned, it was.
MADDOG
Living in a Firepit
6.4L HEMI
yup...that's what it is. It appears the truck was tuned at one time or another.
