hockeygod514
- Jan 15, 2013
- 2
- 0
- 2013 ram 1500
- hemi 5.7
(re-post from tech forum)
I have a 2013 ram 1500 5.7 hemi with 40,000 miles on it. Out of the blue I started to hear a tick, increased frequency with higher RPM, and also got a check engine light. Took it to the dealer and they pull a P0305 (CYL 5 misfire). They suspected a lifter issue right away. the dealer tore the heads off and found 2 collapsed lifters so they replaced all 16. Dealer went to turn it over after reassembly and couldn't start it. upon disassembly, they noted a new faulty/collapsed lifter. days later after further inspection, dealer noted that the camshaft needed replacement for reason unknown. 3 days after that, the dealer calls me says the forward camshaft bearing/bushing which is press fitted into the block, is scored and cannot be replaced per Chrysler. As a result, the dealer was sent a new block/lower end.
I have been unable to find a hemi diagram that identifies this camshaft bearing. Does anyone know what the part number is, and knows if this bearing is really a non-replaceable part? Thanks a lot.
NOTE: Oil has been changed every 3-4 grand by the dealer under 36,000 warranty. All parts/work will be covered under the 100,000 powertrain warranty)
