2013 3500
13HD3500
CBS, NL, Canada
Hey guys,
Having a couple of problems with my 2013 3500 ST DRW....
1). High Beams - Flash to pass works (pull stick back) but I've got nothing when I push the stick forward...I'm guessing it's the multi-function stick but just wondering if there's anything else I should check first?
2). Trailer wiring...Every-time it's wet out I get the check trailer brake wiring message multiple times (3-4 times a minute) popping up on the dash with no trailer in tow..probably a dirty plug? Also has the plug in box for 5th wheel hookup if that matters.
3). I'm getting Battery Saver Mode a lot as well, it's pretty cold here. Both batteries are in blankets and dash is showing 14 volts running down the road. Was going to clean up the terminals and spray them, anything else I should be doing?
4). Engine Brake - It works at highway speeds and slows the truck down to around 70 km/hr then cuts out and the truck rides neutral until I stop...is this normal? Never had a pickup with one before so unsure. And what's the difference between Full & Auto?
Thanks!
