2013 Headlight Replacement with Recon Lights
hzemall
Diesel
Hey guys, working on a 2013 Ram 3500 and we are removing the factory projector/led light to install a set of black Recon headlights. We have everything working fine except it keeps showing a turn signal light out code once we start the truck. We have even installed a halogen turn/DRL bulb and installed a 6ohm 50 watt resistor in the turn wire (other side to ground) and also on the DRL wire and it still trips the code.
Has anyone seen this issue?
Thanks
1500ram12
5.9L Cummins
You will be disappointed with the output of those lights. You would be better off either finding someone with the black oem projectors who would be willing to swap and adding HID's or opening yours painting them and adding HID's
Sent from my SCH-I535 using Tapatalk
H
hzemall
Diesel
Just installing what the customer has bought, have to get this to work :)
