2013 headlights
Junior717
I have a 2013 ram with its regular headlights. Would I need to mess with wiring if I want to install the OEM Dodge projector headlights?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Retroshop it is...anything you need for your headlights he can get you (or do for you).
J
Junior717
I found some oem projectors for cheap. Only thing is that one of them has the screw base broken. Would that be a really big problem with them?
J
Junior717
I found some oem for cheap but one side has a screw base broken. Is that a big problem?
BlownGP
Houston/Baton Rouge
You mean on the bottom front screw?
Just zip tie it to the hole.
J
Junior717
I believe so. One of the tabs to hold the headlight in place
Coolmaxt
I was literally going to ask this today. Lol
Same goes for the LED tail lights right?
