brenth2369
I’ve had a lot of questions about the throttle relearn. If I fix my issue but don’t do the throttle relearn, is it not going to show that any codes are fixed? Meaning every time I do something I have to relearn before I know the codes are gone? Cause in that case I’ve probably wasted a lot of time. And last question, does the manual relearn using the pedal and cycling the key actually work or is that just a myth / older models?
