2014 5.7 8 speed showing p1b14
AllRamz
I replaced the valve body on my 2014 hemi 8speed and now it won't come out of park and I'm getting the p1b14 code also had p1b13 a couple times. I know they say the fluid level can cause this but i have it filled as much as I can without being able to run it through the gears. Anyone have any ideas what can be causes this?
huntergreen
Marine Corps Navy Badge
Did you jack up the rear of the truck to level the trans ? If not, you may be able able to add more fluid if you do this.
A
AllRamz
That was the first thing I tried, I was thinking the same thing. Does anyone know what fluid line I can take off higher in the system to pump more fluid in to eliminate the level as the problem?
ameer73
