sparkybg
- Jul 21, 2022
- 8
- 10
- Location
- Sofia, Bulgaria
- 2009
- 5.7 Hemi
it s 2009 5.7 GC with 545RFE. Sometimes (once every 5-10 starts) on start after 1+ hour stay, for 10-20 seconds there is almost no output from the transmission. Replaced both filters with WIX, the bottom filter seal is also replaced. The problem persists.
Where to look next?
I'll try to start with live data logger and make a movie, but since last time yesterday when it made it,it refuses to do it again. It will, I am sure, but it is hard to tell when.
- 65RFE torque converter replaced recently (from rockauto), maybe 4000km back
- Sonnax valve body with Standart Motor Products solenioid block, 40k km back
- Replaced oil pump 60k km back with rebuilt one (Sonnax valves etc.)
- All clutch packs upgraded - single sided UD and OD form 68RFE, 4C Raybestos, 2C Red eagle+Colene, the rest Raybestos standard, 40k km back
- All pistons replaced, 40k km back
- No shavings in the pan, perfect trans fluid and level, no burnt smell.
- No DTCs, no limp mode, the transmissions works and shifts fine after these 10-20 seconds.
- On hot idle (608RPM) requested pressure of 8.6bar (125psi), actual is around 6.4bar (93 PSI) - 6.8 bar (100PSI) - is this normal?
- On cold idle or 800+ RPM actual = desired
Where to look next?
