2014 Ram 3.6L Gas looses power under load
usbp_603_best
Las Cruces NM
3.6L Gas
Hi all, so I’m new to Rams and to this problem. I have a 2014 Ram 3.6l gas. Normal around town driving no issues but when I get on the interstate and it has load or high demand for a while it will suddenly loose speed, govern down, and the traction control light and check engine light come on. If I pull over and turn it off and on the traction control light goes off and all power/ speed is restored. What could cause this?
jws123
nj
You need to have someone with a good scanner scan for codes not a autozone scanner.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
As mentioned get a Scan from a Mechanic,, Auto Zone shops only have a basic scanner ! If you have a regular shop most will not charge you for a scan !
Your problem could be anything from a weak fuel pump to a bad catalytic converter ! bad coils etc ! Hard to trouble shoot over the net !
